select any mp3 you like and want it as ringtone and then copy it through the pc suit to the phone with the mp3 converting ON and once you got the wav on your phone the size is small and it sounds very good too....
Its the easiest way to convert wav in to mp3 (or well thats what I think)
you should give it a try if u already havent😃
hope it helps you guys
easiest way to convert mp3 in to wav for ringtones
i've tried that b4...but its still in mp3 format...though the convertor thing is still on....and i can't play it...cuz its in the wrong format.. :cry:
hmmm....that has only happened with one mp3 i got
try sending someother mp3 it should work :-?
Funny thing it converted fine for me too... except that I forgot about the converters and wanted an mp3 file on my phone to test the mp3 player. Well I was looking for a long time for that mp3 file and wondering what was wrong with the mp3 player and why was it not finding my song.... hehe I am so stupid sometimes.
Sorry, but i didn�t get it :frown: that converting mp3, is in the PC or in the phone?? 😮
Where and how do i know if it�s ON or OFF???
Marius wrote:select any mp3 you like and want it as ringtone and then copy it through the pc suit to the phone with the mp3 converting ON and once you got the wav on your phone the size is small and it sounds very good too....
What i do is:
1- Use Nero Wave Editor to select the part of the file i want
2- Use CDex to convert it to wav / Save to wav from Nero
