I installed the PC Suite(latest version 1.5.1 frm www.sonyericsson.com), connected the SyncStation(checked hardware-running fine). When I put fone on cradle, that icon on the task bar(the one with two arrows in oppo directions) changes to the one with the "wave" running through it. right-click, properties, USB COM3 CONNECTED. But it doesn't recognize my fone. I go to the PC Suite, n there is an icon saying NOT CONNECTED. N i keep getting error messages, phone not connected, could not find SE handset!
If anyone has any suggestions, or help(NO MATTER HOW STUPID IT MAY SOUND) pls do reply.
Tnx,
Xerxes.
HELP!!! Problem with PC Suite!
did u do a search ?? on the forum there is loads a topics with suite problems more then u can think of just give it a try .......... 😉
and meanwhile olso check ur serialport speed might help to change that
:angel:
