I've downloaded it but it's just partially installed. Whenever it try to install it it only sez, Installer:system error, try again. How can i install it completely?
Help with real player
You've probably not got enough memory to fit Realone onto your 7650. If you're sure this is not the case, then try to delte the .sis file (the installation file) from Appman (menu-tools-manager) and start over.
Can i make a suggestion that Oplayer is perhaps your better bet. Not as big as Realone and IMOH, better. Check it out at http://www.oplayo.com/products/oplayer/
Lee 8)
