color palletes
8 replies · 2,017 views · Started 09 June 2003
is there any way to add more color palletes? currently there's only Blue, Green and Purple. How do I add more colors?
To use pExtender though, you'll need firmware version 4.xx
3.12 and 3.16 are no good. Check your version by keying in *#0000# when in standby mode.
Lee
Is there gonna be any more colours available than the six we can get now? Likea sexy black? How about an app that could let you create your own colour just from mixing the three primary colours together?
Unfortunately, I don't think so. The colours are coded into the OS - faquick's app actually makes available 3 colours which are in the OS, but had not been made available by Nokia.
Or are you thinking about apps like launcher/skin editor to change your menu screens?
Paul
Wether you are thinking about something like palette extender or SmartLauncher skins BOTH subject have been treaten before in this forum. IT IS SO DIFFICULT for peopple to use the !!!User posted imageSEARCH !!!
No i meant pallette extender i wasn't keen on smart launcher. Thanx for the help liverpool lad. It's good to know certain people can answer questions without an attitude problem, unlike certain others in this forum. If there was a search option on AAS wap i'd use it but there isn't.
[quote="machen"] If there was a search option on AAS wap i'd use it but there isn't.[/quote]
Accept my apologies then. But there's plenty of peopple that does that even when they post using a regular PC connection.
