It was an option on previous nokia models. Anyone knows how to do this?
How do I delete the entire calendar?
I dont think you can because its on the "Read only" drive of the phone and nothing can be deleted from this. 😃
Do you mean delete entries? You need a file explorer and delete the calendar file found in C:\system\data once it's deleted it will leave 365b of information. 1 byte for every day which is very small and not worth thinking about. Hope that helps
NO need to do that.
It's in-build inside your calendar. Option-> delete all entries-> click yes.
Can't find that option in my calender app Edgedale :-?
Lee
No neither can i? What software version are you running edgedale? I've got 4.39 it does seem strange nokia haven't included this. The only way for me is to delete the file with file manager/file explorer.
Make sure you're in the Month view first, then Options -> Delete entry.
