how to convert MP3 to other .ext ?
6 replies · 2,873 views · Started 11 June 2003
hi all,
i recently purchased a 3650 n im having some difficulties transferring mp3 files to the mmc using the PC suite.
Can any one offer some advice?thanks
Newbie 😃
i selected a mp3 and then copied it through the pc suite to the phone via ir with the mp3 converter 'on'.
the file transfer stopped halfway and this msg "file transfer not complete"
appeared...
the same problem occurred even when i tired out other mp3s.
There seems to be a problem transmitting large files over IR. I had a problem also over IR but it worked over BT. Not sure though, can someone please comment.
personaly i have no prob with sending over IR...
++i cant get my mp3 player on the fone working
