App to send ringtones ??
6 replies · 1,642 views · Started 11 June 2003
is there any app for the 3650 so that i can send my ringtones (selfcomposed or on the phone) to other nokia mobile phones ?? All of the nokia do use some same format for ringtones so this must be possible, or ?? I tried to send it via seleq and infrared to my 6210 but it doesn't accept the connection 😞 So is there any app out there ?? Sending it per sms would be great....
I havent heard about it.I tried to send files to Nokia 7210 and 7250,but no result.I sent files to SE t68i,and all was ok.
If you mean polyphonic (MIDI) tones, they cannot be sent by SMS. Also, DRM (digital rights management) prevents you from sending them via MMS.
No, you can't do it with ringtone studio. You can only "Send ringtones via MMS, IR, Bluetooth and Email". But via regular sms to "older" handys. And i don't mean polyphonic ringtones. The way to do this is listed under http://ringtonetools.mikekohn.net/ ,but there is no tool for the 3650 😞
Oh ok, well i wasn't 100% sure with my last post 😮ops: 😊
It's a shame that this cannot be done. Perhaps any developers out there listening? 😉
Lee 8)
