FE EXPLORER EFFECTS??
24 replies · 4,522 views · Started 12 June 2003
So now that I finally go the FEEXPLORER what cool things can be done with it? IS there a manual online somewhere or a tips and tricks page for newbies like me. I appreciate the help all. :black:
I think that you don't need manual because it's very intuitive (hope so ...)
just that :
joystick to the right : one directory down *on* a directory
joystick to the left : one directory up
joystick up and down : up and down in the lists
for the other, use the menus !!
Hope you'll enjoy with it !!!
Domi.
[quote="NokiaNumbnuts"]Well thanks for nothing there fuckos! :2gunfire:[/quote]
What the hell gives you the right to call jimmy floyd or Domi (especially Domi, because he is the CREATOR of the FREE software that he spent time creating, and that you are using) "fuckos"? They both tried to help you. They spent their own time and energy to be considerate enough to help you, and then you treat them like this?
Grow up.
Domi, great programme. One question for you--I find that folders sometime get cred n there own--or perhaps after I have done somecreate them likemove anage around, instala new app etc. I find that smes I have repeated folders in both the C and E directories. i find myself having to do a lot of house cleaning. Anyway around this--other than don't move images, videos and apps around?
Domi, second question: I have version 1.08. Is there a big difference between that and 1.10? Or maybe I should ask, what are the major differences?
humm Peter, I don't undertsand very good your first question ???
for the second, clic here : http://users.skynet.be/domi/version.html under current version 1.10, you'll find all that is new since the last version i.e. 1.08 (I think it's better to upgrade b-cause there are a lot of new points)
Domi.
Never mind about the first question. Thanks for the link and the best programme there is for the 3650.
Just downloaded and installed v. 1.10 (over existing v. 1.08). installed it from PC to MMC. Installation went smooth. Everything seemed fine looked at some features and files and then after I existed the first time getting constant Fexplorer System error message. Keeps poppg up and beeping. Powed of the phone and same thing happens. Any ideas?
It would be a waste of time to make TUTORIAL.
FileExplorer is very USER FRIENDLY just like all the file explorers you can find arround.
Never had one problem with v. 1.08. Installed v. 1.10. only Fexplorer System Error messages evertime I try to open Fexplorer. Everything else works. Please help with any ideas Domi or anyone else has. Thanks
[quote="peter"]Never had one problem with v. 1.08. Installed v. 1.10. only Fexplorer System Error messages evertime I try to open Fexplorer. Everything else works. Please help with any ideas Domi or anyone else has. Thanks[/quote]
Uninstall and then install 1.10 again.
[quote="jimmy-floyd"]YOu dont need any FAQ on FE explorer,coz it is explorer,like in usual windows.[/quote]
exactly
About your problem Peter. There is no such thing as an "upgrade" in the PC sense of the term for the N3650. You have to uninstall a program and then install the newer version. ALWAYS. Otherwise things like what you experience occur. I don't think I ever seen this well documented anywhere but the good people have told me about it.
Hi again ppl i have FExplorer V1.07 can some1 tell me wots the latest and best version outthere at the mo and also can some1 post a link for it so i can download it thnks in advance
V. 1.10 is the latest Fexplorer. Great programme, made even better than 1.07. Make sure you uninstall 1.07 before installing 1.10 or you could have some problems.
ok so where do i get v1.10 from?
and also can some1 post a list of the changes and differnces made maybe Domi the genuis who made the program lol
thnks in advance
Here you go. www.gosymbian.com
There is a long list either on the site or during the installation process about the new features and differences.
found it now guys thnks.. yeah its better i like the new version it kinda helps me see wots going on and wots wot
