FileExplorer 1.10 released !
9 replies · 8,971 views · Started 13 June 2003
Hi to all of you,
just some few words to announce that FileExplorer 1.10 is released !!
The versions are available for download thru the 'official' site :
www.gosymbian.com (in the download section)
Thanks for your support,
Domi.
what's new in version 1.10 :
* a message is displayed when a screenshot is saved.
* added the time in the properties of the files and the
date and time in the properties of a directory.
* the number of the last screenshot is saved and continue
with the next version (to avoid overwrtting).
* the icons associated with the files (if so) are now
displayed in the list.
* you can now turn the infrared ON from the Tools menu.
* I have improved the quality factor of the images captured
with the screenshot, the image is now captured at
176 x 208 instead of 176 x 188.
* it's now possible to run the .EXE files (not only .APP,
ex: to run console applications).
* in full screen mode, the size (free/total) of the drives is
displayed at the top of the screen if activated.
* before exiting FE, the last directory is saved for the next
use if selected in the settings.
* the network info box displays also the area id and the cell
id.
* when exiting the editor-viewer, the previous path is kept.
* it's now possible to delete read only files after a
confirmation message.
* some shortcuts have been added :
<KeyPad 1> : copy <KeyPad 3> : PageUp
<KeyPad 4> : cut
<KeyPad 7> : paste <KeyPad 9> : PageDown
<KeyPad *> : go to root <KeyPad #> : file properties
Can someone please post a direct link to the file so that i can download using my wap connection. Well done again domi. By far the best series60 filemanager.
Great Domi! Thanks!
Gotta install it when i get home. ATM i got the beta version of it and it has worked great.
After installing v.1.10 I didn't see it anywhere on the my 3650..
Old version used to work fine.. :cry:
Just thought about the same problem, but it will solved automatically after a restart of the phone.
