shift + backspace = del
8 replies · 4,250 views · Started 15 July 2002
I am sure every1 know this and somehow i am the only one that missed this in the guide (that i did not read hehe!)
But if you hold shift and press the backspace key it works like a del key on a PC.
Ok so nothing major but handy sometimes
[quote="KayonLord"]I am sure every1 know this and somehow i am the only one that missed this in the guide (that i did not read hehe!)
Ok so nothing major but handy sometimes[/quote]
This is a test post, you'll undersatnd why later.
Okay how bout the KLU KLUX KLAN trick??? u know that??
Try it... it's shift+ctrl+chr then press KKK... it'll kill everything and reboot your 9210...
[quote="Nosferatu"]Okay how bout the KLU KLUX KLAN trick??? u know that??
Try it... it's shift+ctrl+chr then press KKK... it'll kill everything and reboot your 9210...[/quote]
will this kill 9210 literally? U mean this will reboot and format 9210? 😃
Ah the delights of legacy code from the SIBO Series 3 developers. This trick (and a few others) are so entrenched in certain Symbina codes minds, that they were slipped in to ER6, even though they were never part of the design spec. I think ctrl-esc has the same effect on early builds.
Must dig out my list of undocumented shortcuts...
I use Restart from PSILoc: it's free and kills all progs and restarts 9210.
But only to kill some/all programs don't use the utility from PSILOc -its memory intensive! I use ISwitcher - it's 48 KB only
Hello,
Where can I find, try, buy and/or see this ISwitcher application?
