Images for the right panel
32 replies · 6,600 views · Started 26 October 2001
Could we (the mortal people, hehehe) create our own images for the 9210�s right panel?
What will we need to can do it?
Regards!
Yes, it's quite easy, you need a piece of software called BMCONV.EXE which is available on the 9210 SDK and 4 bitmaps. I'll e-mail the file with instructions to you.
Regards
Patrick
www.n9210.co.uk
Im going to write a little thing that will be up at my little corner soon.. User posted image
Im testing some new dimensons for the panel.It�s told that it should be 130*200 but it�s more like 100-110*200.It�s anoying that the pice get�s chopped when displayed in the 9210.You can see how it has chopped off a bit of the nose in the Civil Planes 1 skin I made (first screen) <A HREF="http//loonyworld.homepage.dk/9210civilplanes1.html" TARGET="_blank"><B>H_E_R_E</B></A>
Anyways.. I want to be able to calculate with the right screen edge, and i guess so do you. User posted image
And when it all come to all..It�s fairly easy to make them, it�s just time consuming like hell..
I�ll hurry up a bit...
Hi!
Patrick, thank you very much for your e-mail! We�ll see if I�m able to understand it! hehehe!
Regards!
Hi!
Patrick, now I have not problem about the size or colours of the images. I use 100x200. And when I use bmconv, the BMP files have more of 20000 colours,hehehe, but it works fine writing "C16".
When you put a place on your web page to upload backgrounds+right panel, tell me it!
Regards!
If you want to send them to me you can do so... he hee. I actually have quite a few to go up, just haven't got round to it yet (sigh - term is busy at Uni atm). There up somewhere (mainly loony's actually) juts no pages to link to them.
Rafe
Hi!
Rafe, no problem about that. But I have a problem my device is crazy. Last night when I was testing my right panels images, the Clock of my device began to change its time by itself repeatedly. A few days ago I had the same problem after installing Terra Force, and I thinked that this game was the cause. Then I uninstalled the game and it was ok until last night.
I dont know why it occurs...
My device has more bugs,for example, the direct acces Ctrl-l doesnt work in Word or RingMaster...
I have the 3.54 version. Must I format my device?
Have you any idea?
Regards!
Hello to all !!!
Just a simple question (I hope).
I have being using a great tool, from LOONYWORLD. But it seems that the screen resolution colors for the wallpaper is not adjusted to the right screen picture. Is there a way to correct the screen resolution, in order to have the same levels and equal colors for both images?
Thanks, and (LOONYWORLD) keep up the good work.
Regards.
Thank User posted image
I know about the Resolution issue..
<TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote</font><HR></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR></TD></TR></TABLE>
But I too ended up with a 100*200 res..Just like the good Manowar said..
So the civil planes gets an update..
The other skins I did does not suffer from being a tad bigg.
But ofcourse all new ones will be propper sized.
Simpsons in the works, along some other cartoon skins... User posted image
The colour correction is there nothing to do about..The fact that 1 pic is .jpg and another is .bmp makes it impossible to make it perfect.
Or is there ??
Greece...I love Greece..Mom and Dad used to haul us down there every summer when I grew up...Best food on the Globe.. User posted image My mom even dances Greek folk dance..
(sorry..had to say it when I saw you where from Samthepaokfan).Damm I can even smell the Cypress trees and taste the Tzaziki as I write this...Ummm..
sorry for going off topic..
But as always...Working hard to serve your happynes...
Thanks for the answer & for your holiday memories from Greece. Hope you enjoyed yourself there... Plus, you made me hungry with the tzatziki and other smells...
Back to topic...
When I speak about screen resolution, I mean that when I install your tool, at first choosing the wallpaper, and after installing the rest as mentioned on your web page, there is a difference in colors with the right screen. I mean the result is that the wallpaper seems to be blurred & less sharper, and the right screen is sharper & brighter.
Question. Is it possible for you to work on a solution to include as well the left screen?
Thanks & regards from sunny Greece!!!
Yes, there is a color difference with the right panel. Before the copy of the files to my comm, what I do is open Photoshop, hehehe, and adjust the colors desaturating the images of the right panel. And after that I check the colors on my comm. Its so boring, but....
Regards
Ola Manowar!!!
Translation time... What do you mean by... and adjust the colors desaturating the images of the right panel.
How can you adjust the color for the right panel, when the only file available is the wallpaper. Maybe I am just a Greek, and its too complicated to me???
Thanks for the help.
Hehehe, I�m sorry, you are right.. Well, what I do is adjust the images ON MY COMPUTER (with a photo editor) BEFORE convert them to one MBM file, and then I copy that file to my comm.
You are right, you can not adjust the images on your comm directly. You need a DOS command to make your own images for right panel.
If you are interested, ask to Loonyworld again (the master,hehehe) or go to www.n9210.co.uk and ask to Patrick about this. I�m only a beginner, hehehe.
Anyway, the color difference is not so bad to can see a difference between panels.
Perhaps, with a photo editor, you could saturate or grow dark the jpg desk background to be like the right panel.
Regards and good luck!
<B>Hi Guys...</B>
Well..in my opinion, Color adjustment is perhaps the trickiest part in this.There are so many factors.True that some desaturation and grow dark will make them more even.But a perfect match can never be accomplished (I think).There is also the viewing angle and enviroment luminans to think about then.And the fact that they are different formats.It�s also tricky to catch the different Brightness settings.And then there is even that milky white transparency on the desk part.
The LEFT side panel..Hmmm..I dream about it too User posted image ..But some wise people told me once that it�s impossible to put a texture there..Only custom thingie for that is the
<A HREF="http//www.epocware.com/nokia/colors.html" TARGET="_blank"><B>COLORS</B></A>
program..But, WOW , imagine a fullscreen skin...Sooooo Sweeeet User posted image
Perhaps someone cracks the nut ad figures it out..I hope
Ohh...The best tutorial at the moment is right here at this lovely forum User posted image ..I learned it all from here..It�s all <A HREF="http//www.allabouter6.com/phpBB/viewtopic.php?topic=52&forum=1" TARGET="_blank"><B>at this topic</B></A> User posted image (some pics are missing due to a server switch, sorry)
Well im off..back to makeing more skins
Grrrrrrr.....100*200 won�t do either..
Too small..
I�ll make a test screen skin to measure the resolution so we can get that optimal screensize once and for all....
Check the iregularitys in the Newson skin..
Not to bad to make it sux(Still my personal favorite skin)...But it�s not PERFECT.....DOOOH User posted image
Maybe a 103-107 is it ....Hmmm...
Must go measure..Even if I have to stay up all night...
Yes, 100x200 is too small.
Anyway I think 107x200 is small too, because when I open some apps the size of the right panel increases.
I think there�s not an especific size.
Regards
Yes indeed too small..
The good ��� said..
Hi my friend
The size is 113x200 but i think it's not good for all show in 9210. Some times need biger pic and some times small one.
I think the 113 wide it's the best solution.
And they seen to be right on..SO.I know im making the next ones in 113*200.. User posted image
So how the 100*200 ended up in my calculation must be a mystery.
Happy Happy Joy Joy
Have you thought about making the image as one large one, saving it as a .jpg, then, 'cutting' the end off to become the right panel image and saving that as the bitmap, then re-saving the .jpg.
Or am I getting the wrong end of the stick and the problem is with the translator on the Nokia for mis-matching the colours.
BTW can someone send me the converter prog so I can do my own wallpapers and panels, while I await my SDK.
Flipside
Have you thought about making the image as one large one, saving it as a .jpg, then, 'cutting' the end off to become the right panel image and saving that as the bitmap, then re-saving the .jpg. </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR></TD></TR></TABLE>
Hmmm...Thats exactly what i�ve been doing up to now.. ;
So i guess yes..You got the wrong side..The problem is with the translator on the Nokia for mis-matching the colours
It�s a bugger..But we�ll live..
Wonder if this any helps... just quess
Resolution 640 (x3) * 200 dots
Active area 107.52*33.6
Dot pitch 0.168*0.168mm
Frequency 51.5Hz
Colors 4096 12-bit RGB
Oh JeP.. User posted image
You are always fresh with those basic facts...Thanx.
Witch reminds me I should make a Honour skin for Rafe, Jan, & JeP..You are da dudes.. User posted image
Ooh... that would be nice User posted image
Hmm, i kind of like that "allabouter6" skin what i have been use for a long time User posted image
You're the man also!
I'll keep in touch..
Damn machine...
...That was me... User posted image
Loony - I already consider you to have done loads - your doing great work for all of us by doing these skins. And you made me an all about er6 skin to use (if I could).
Keep it up.
Hope your enjoying your new software User posted image
Rafe
Juan,
Necesitas un programa de DOS, es un poco complicadillo... Tienes que hacer primero las im�genes con el tama�o necesario y luego compilarlas con el comando DOS en un s�lo archivo MBM...
Si pides por aqu� el programa quiz� te lo pasen.
Un saludo, tocayo User posted image
hello all i have a question i looked in forum.nokia and cannot find BMCONV.EXE can anyone help me find it?
Thx
Yes i have found it but when i open it i see a screen flash and then nothing.
so what am i doing wrong?? User posted image
An oder question can anyone send those SDK cd`s from nokia forum because i ordered them 5 weeks ago 3 times a week and nothing yet.
is there anyone who can help me with that???
Thx a lot
