Using Nokia PC Suite for 3650 I am able to synchronize with Microsoft Outlook on my PC. I have edited my contacts extensively on my PC (in Outlook). I want the edited contacts (from Outlook) to replace the existing contacts on my phone. Is there anyway to set things up so Outlook overrid the 3650 during synchronization so that the new/edited contacts prevail? Thanks
Synchronizing with Outlook
It's not very obvious but under the Syncronize menu there is a configure tasks option. There is a manage tasks button. Click that then select your task and click properties. Then click change in the Task details secion, a window will open where you have to click change again. There go to the general tab an select what overwrites what. Very cluttered.
Hey thanks for the help. I was wondering when someone would answer. Congrats on your promotion, I see from your title under your avatar you have been bumped up to Forum Elder. Well done.
Thanks Peter, I guess I post a bit too much... but helps the workday pass, if you notice I don't post on weekends.
Glad was able to help. Cheers.
