Where are the files attached to messges stored?
2 replies · 1,827 views · Started 27 June 2003
I would like to find this out so I can have multiple GoBoy roms on my phone and switch them by copying files. Unfortunately FExplorer is not finding the attached file. Where does the phone store them.
Thanks in advance.
Erm...u mean you currently only have one gameboy rom in your fone?i have over 10of them sometimes 20 and its okie...just copy them in your fone memory any folder,the emulator should find it itself,i just create a folder called "gameboy rom" and copy'em over,tats abt it! 😊
Thanks, it worked and now i can load some ROMs. Feel kinda stupid though that I could not try this myself.... laziness is definitely present.
I still would like to know what happens to the files attached to messages that the phone recieves. (I sent the rom via BT by using the XTNDconnect send feature and it was nowhere to be found by FExplorer
