little help here plz
12 replies · 1,668 views · Started 27 June 2003
Trying to maximise memory on the phone memory on my 3650 I started looking around for big files to cut and paste to the memory card. I know its stupid now, but i really wanted opera to work and slauncher wasn't working. Anyway i must have done something tot eh applications part of the phone cos now it doesn't work, just says system error. However it onlyy comes up on applications, nowhere else. Any ideas?
Sounds to me as if your trying to move apps to the MMC card which cannot be run from there and the byproduct is the phone throws up errors.
I know for certain Smart Launcher cannot be installed onto the MMC card as it will cause the fone to give out errors left, right, front and centre.
Opera may also be the same. If your having a problem try removing the MMC card and booting the phone. If the previous statement is right in this case your fone will boot no problem and work 100%. If so format the MMC card preferably outside of the phone with a Smart Media card reader and then install it back in the phone. You will have lost everything on it but you can always put it all back on. Again check all the apps you intend to install to see if they are MMC ready or not, most if not all will tell you as it is a common problem. One that is being fixed in the majority of apps.
Hope this helps, Ian
thanks, what had happened was that i had moved the helicab.jar file to the e: drive and that stopped all the apps from working. Unfourtuantly, i only realized this after i had deleted all 200 apps off my fone. Because most of them were bought i have no way of getting them back. Bit of a waste of money! 😃 😃
[quote="sco2001"]thanks, what had happened was that i had moved the helicab.jar file to the e: drive and that stopped all the apps from working. Unfourtuantly, i only realized this after i had deleted all 200 apps off my fone. Because most of them were bought i have no way of getting them back. Bit of a waste of money! 😃 😃[/quote]
I'm preety sure that if you contact the companies you bought the apps from and explain your problem they will be more then happy resend you regestrations.
Not to mention that installing 200 apps at the same time is a rather shaky proposition on your 3650. Even if you install to the MMC they still take up a little room on your internal memory, therefor decreasing your avilable operating memory.
Also a good idea is to test the phone for a little while after installing each app. This way you will know if there is a problem which app to delete. In this way you can also make a list of the apps that work so if God forbid you need to reformat the phone you know which ones to install safely afterwards.
I wasnt talking about symbian apps, i was talking about java apps and so far the only company to send me another copy is overloaded.com. They have fantastic customer service. They even sent me a version of resistance that apparently is the only copy in the world-it supports bluetooth deathmatches against up to 4 people. Does anyone else have this version or were they telling me the truth?
You'd better hope that some other people do have it...else your 4-player bluetooth deathmatches won't be very satisfying.... 😉
yeah well thats the problem. The file is just sitting on my computer, and i'm, pretty sure that i'm the only one with this so far. Might try it with a few friends
Yes, please to be talking the speak better. I unnerstand no english and am dumb fuck foreign assface. Please come to this one here for understanding. my ass is full of my face. But I love 3650! :bday:
[quote="Yimmy-Floyd"]Yes, please to be talking the speak better. I unnerstand no english and am dumb fuck foreign assface. Please come to this one here for understanding. my ass is full of my face. But I love 3650! :bday:[/quote] who is you,and what are you talking about. 😮
ROFL The only problem is this might provoke another series of 7 or 8 posts from jimmy saying.... nothing. Finally got a warning did he.... about time.
