face plates
15 replies · 2,725 views · Started 27 June 2003
:angel: how do i change the face plates for the nokia 3650
please search forum for an answer before asking questions that are likely to have been asked before.here's an answer to your problem originally wrote by maxx, in a thread not worth mentioning:
i actually have the solution. i ran into the same problem attempting to take the cover off my attws 3650. i was convinced there had to be more than one tab holding this thing on. trust me guys, you feel pretty embarassed when you're a grown man having trouble with something that's called an 'xpress-on cover'.. so after being laughed at by a few 'technical support' people at nokia, they suggested i take it back to attws... but i called later on about a totally unrelated issue and a very helpful guy told me that there are four tabs holding it in place.
if you push down on the top tab, and pull the face away from the phone
then squeeze on the sides, just between the irda port and the indention in the white region (and equivalent place on the other side),
the cover should pop off with the bottom catch coming off last.
apparently, some 3650s come with the xpress-on covers stiffer than others... i had to apply a great deal of pressure on the sides to get it off. i had been pushing all around the sides, but that half-inch seems to be the magic spot.
hope this helps (and brings peace back to the forums!),
maxx
hope it helps.
TaTMaN
http://nokia.iwebs.cz/galery/index.php?galery=n3650&album=Nokia_3650_coloured_covers&window_width=800&screen_widht=500&screen_height=600
forlan Posted: Sun Jun 29, 2003 5:30 pm Post subject:
they are xpress on, not xpress off that�s with almost every nokia phone..
Right on.... ever try to take the back cover off a 7250... ouch
Oh yeah and how do you do that nice Forlan wrote thing on the quotes, I know unrelated dumb question but would like to know. 😮ops:
2J2K,GHOSTDOG,and other moderators,SOMEONE try to make us angry,someone is crashing our forum,who is that bastered man
That moodi boy posted messages twice yesterday,here his name is moodi 2,and in other topic,his name is jimmt-floyd2..
It�s pretty simple.
The one above I put like this [*quote]the text you want to quote copied here[*/quote] But it�s without the asterisk marks (the "stars"😉. Or you can just press the quote button on the post-a-reply screen and then follow tha orders 8)
and thank you kirill for trying to help me with this bluetooth thing, but as known, nothing works with my bluetooth 😉 :cry:
Hello guys!
In our country, transparent faceplates are now available. They are only class A but very good quality!
I think there is clear gray, clear violet, clear red and much more!
Most of them are just priced at P300 ~$6 each.
