Hello,
I have a problem connecting my 3650 to my PC. I installed a Bluetooth USB adapter from Trust, and got me the program PC Suite.
After a lot of trouble, reading threads on all kinds of Forums, and 15+ hours of work, I got mRouter to connect to the correct port. However, PC Suite stays in "offline mode" - it says "not connected"...!
How do I get it to connect??
When I open the "change device" menu on mRouter, it says "Nokia3650 not connected" (but the right port is checked and seems to work).
Some other peculiarities:
* When starting up, I get the message "can't perform this action because the other device is busy" (or something similar).
* I have TWO mRouter icons in my system tray.
* In My Bluetooth Places, it says the "Bluetooth Serial Port on Nokia3650" is not connected, but next to the Nokia 3650 icon, it says "Paired, Connected". When I click the Serial Port, I get "Could not establish connection" and the window suddenly collapses. However, sometimes, mRouter will switch on, and I get a pop-up that my Nokia has successfully connected.
If there is no solution for this problem, is there a way to move files to and from my Nokia without installing PC Suite? I tried something:
* In the Nokia 3650 menu in My Bluetooth Places, there is the option of "OBEX File Transfer on Nokia 3650". I can use this to move files into my phone's Message Inbox, but I can't move them out again of the File Transfer window (I can delete the messages from the Inbox though). I can't get any images or files =from= my phone.
Thanks in advance!
-- BFM
Specs:
* Trust Bluetooth adapter
* Windows 2000
* PC Suite (newest version)
* Nokia 3650
Another thing: on the Nokia website, it says the Bluetooth software should support "serial port protocol" (SPP). How do I know whether my BT software does this? I tried to Google for it but came up with nothing.
How necessary is it that it supports SPP?
I have the same prob, except I can�t get anything into the phone. My obex filetransfer doesn�t work. I have win98se, but there�s no "my bluetooth places" or anything like that.
http://discussion.forum.nokia.com/forum/forumdisplay.php?s=&forumid=38
have a look hereI got 3650 to sync vi bluetooth.
1. I removed all the software
2. installed XTNDConnect Blue Manager V2.2
3. Rebooted and got the 3650 to connect.
4. Installed 3650 sofware and rebooted
5. Disabled my IR device on PC
6. Set mrouter to com7 and connected the phone
somehow it then worked, but this is on Windows 2000, tried the same at home on my XP machine and its a no no 😞 ??
[quote="jamminj"]
[/quote]
What kind of program is this? Where do I get it?
[quote="jamminj"]5. Disabled my IR device on PC
[/quote]
You mean you have some kind of InfraRed device on your PC, in addition to the bluetooth dongle or card?
the XTND connect is the drivers that came with my bluetooth usb dongle, I think its EIO Wavelinker?
http://www.ivmm.com/download_eio.html
I used to use an Actisys IR serial port dongle.
hope this helps 😊
Don't just download XTND connect if your BT dongle came with another software. The program, even the latest version has it's large share of problems working with mRouter. I got it to work in Win 98SE but it refuses to cooperate in XP Pro.
Thanks - didn't do that.
Somehow, I got the regular file transfer function to work, by installing the TECOM software (I have a Trust BT dongle).
I'm thinking of just abandoning the PC Suite - it creates more problems than it solves.
