Can anyone send me a copy of profile.sis program? I lost it after reformatting and reinstalling... pls send it thru [email protected] T.I.A.
Help for profile.sis!
you can actually get it from http://www.nokia.com/phones/productsupport/9210/downloads.html
it's in the All_Nokia_9210_data_v413.sis (I guess you are using communicator software version 4.13...if not, just choose whatever suitable there...)
You can see communicator's software version by entering *#0000# into the phone side...
Its not included in the file... what I really need is the profile.sis program... anyone got this copy?
I don't think it exists by itself (I could be wrong). You install it by installing the All_Nokia_9210_data_v413.sis.
I'm fairly sure the profiles bit is installed as part of it.
Put it another way, after a complete format, I installed the All Nokia files and the profiles bit became available.
Just to confirm, you are looking in the control panel arn't you. If so, then I guess you might have to have another go at installing the above.
Zuber
ehehehe... yep the two of u are ryt.. I made a mistake.. I installed all nokia9210.sis in memory card thats why I cant see profiles.sis... tenx anyway
Just like what people use to say...
"always trust your elders... hehehehe"
