Just recently, when I reset my machine with Task Manager, I get a 'SIM Card Not Accepted' message on the phone-side.
Any ideas why this would be?
just a very shallow suggestion -- try removing your sim card and putting it back again. 😊
Not sure if it is the same problem, but take a look at the thread below.
http://www.allabouter6.com/phpBB2/viewtopic.php?t=82&highlight=
Zuber
I don't really think it has got anything to do with the application...
coz our communicators are well known for the lousy simcard slot...
before i even got the task manager i have faced this kinda problem several times...
the solution??? like what whiplash suggested, try adjusting the simcard... or if needed, just put a little piece of paper to support it...
😃 yeah i know, this way sucks!!!
Don't now about you're problem, maybe the answer is the same to my problem.
If my pda side is fully boted and i haven't loged in to my phone side yet, I get the login on the pda. Nomal so far, but none of them work .. they jsut crash after hitting enter.
something is wrong between my sim and the phone. 😊
Thanks for the advices!
