Can someone please tell me a site, or a few sites to find customisations of themes/icons along the lines of what forum user willbrady has?
Themes And Icons
Hi.
You will need sLauncher from www.symbianware.com and their skin editor.
This lets you change the menu system on your phone.
You can get some 'skins' from their site.
You can make your own backgrounds and insert it into any 'skin'
Attached is my Disney skin along with the desktop background image and operator logo.
You can set the new operator logo using 'seleq' and also you can change your colour scheme to red using 'pExtender' from faquick.
Have fun
Will.
Thank you very much Willbrady, most kind.
can someone help. It may be a bit of a dum question but how do you applt the skins that you make using skin editor.
1) can you make a complete skin with the trial version or can't you save and use the result?
2) i couldn;t find how the create a new skin either, perhaps you could explain it?
there is also beta one pack(some icons)
[quote="sco2001"]can someone help. It may be a bit of a dum question but how do you applt the skins that you make using skin editor.[/quote]
This has surfaced before but Skin Editor makes the skins for software called SmartLauncher. If you have no smartlauncher the skins are useless. If you have it there is an option somewhere to use a pre-made skin.
