Am i the only one who can only have one mgs game on at one time. When i have mgs karting and steelwarrior on i just get the kern error and so i have to uninstall both and start agin. So annoying, is there any way of solving this?
mgs games
NO INDEED! I had 4 games installed some time ago and ALL OF THEM worked fine.
could it be because they are different versions of the game?
[quote="sco2001"]could it be because they are different versions of the game?[/quote] It maybe so.i have 4 diffrent MGS games,and all works.
I had the same problem.. easy to solve when you know how 😊
Check this thread
http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=10480
If u are a 7650 user, u should get the 7650 version of MGS games...
Get the 3650 version if u are using a 3650 which supports the installation to the MMC...
p/s: 😉 MGS WAREZ VERSION might cause this kinda problem as well...
When you install MGS.sis it will tell you your MGS version. Please always put the newest MGS into your phone. The newest MGS should compatible with old ones.
The newest MGS is 1.92 I think.
[quote="Nosferatu"]
p/s: 😉 MGS WAREZ VERSION might cause this kinda problem as well...[/quote]
I have original versions - and I still get the error from time to time.
