3650 audio specifications
4 replies · 5,118 views · Started 09 July 2003
What are the audio specifications of the Nokia 3650?
For example,
maximum sample rate - (44.1 kHz, or ???)
maximum sample bit size - (16-bit, or ???)
frequency response - (60 Hz - 15 kHz, or ???)
also, any information about the frequency equalization curve?
The Nokia 3650 audio quality is not very good.
I ask this information for two purposes:
1. To use best possible audio quality that will actually be used by Nokia 3650 to play audio files.
2. To edit and engineer sound files to sound good on Nokia 3650.
When files are played on the Nokia, they often sound very bad, because they contain frequencies the Nokia cannot playback very well (for example, low bass, high tones).
If audio file is compressed and low-quality audio, it still sounds better on other audio equipment than Nokia phone. The low quality audio on the phone is also the result of limitations in the playback hardware on phone, not just the audio quality of the audio file.
So, it would be best to equalize and edit the audio file to sound better on Nokia 3650.
Please help provide requested information, to help make it possible to edit audio files to sound better on the phone.
Thank you...
P.S.- about "maximum" quality...
Yes, phone will play 44.1kHz, 16-bit file...
But, I ask, what is the actual quality used to play back? For example, it may play high-quality audio file, but the playback is only a lower quality...
Thank you...
Those are good questions. I need to research more about my phone. 8)
The audio sampling might be at 22kHz. 16-bit.
