I've been getting this error message lately. It doesn't seem to affect anything or maybe I just haven't found out what I'm missing yet, but it got me worried. So I searched the forum and found this http://allaboutsymbian.com/phpBB2/viewtopic.php?t=199&highlight=etel
It seems that the two options suggested were format or delete the ini-files. Is there any other option? Has it been figured out what causes this? I never close the phone app but I have been installing + uninstalling something, so maybe the registry is confused... Have I finally reached the point when I really need to format? After almost two years of daily use? 😃 I still have the old 3.54 firmware btw.
Messaging Watcher, Etel Client Faul, Reason number -28
FORMAT!!!!!!!!!!!!!!!!!!!!!!!!!!!!! 😃 8) :P :roll: 😮 😃 😃 😃
Make shure you have all your data, sms, documents, skins, apps, saved or backed up first.
You will need also sis files for your RAE Version.
I guess deleting the ini files won`t harm your commi, but format will improve for shure :robot:
:-? If you're already decided to format, why dont you get it updated to 4.13 as well??? it's about time madam... hehehe...
decisions, decisions... 😃
