What's the name of the original 'Video Recorder' that comes with the Nokia 3650 and where can I find it?
Original Video Recorder
You can find it flashed on the phone, and not as an installable file anywhere.
You can find an update to it on http://www.nokia.com/phones/3650
Why does it take so long for the camera to get started? Does anyone know? Greetzzz
i think there is a slight delay as the button you press for the camera is the first one you use to select the key lock , so it gives you a couple of secs before you press the star key
so its best i dont remove it, cos i can never get it back?
Using hipcam, but still dont wanna get rid of it..
ANYWHERE i can find it?
[quote="Arni"]so its best i dont remove it, cos i can never get it back?[/quote]You won't be able to remove it in the first place (unless you manage to reflash the phone with a firmware release without the camera software).
[quote="racingboy"]Why does it take so long for the camera to get started? Does anyone know? Greetzzz[/quote]
If you remap it to the right softkey then you will get it without the delay it has waiting for you to press *
But why does it take a while he the app is opened and then press record, it take a few seconds, and also if you have made your movie, than it saves automaticaly, and that tickes usually 15 seconds... Is there anything i can do about that?
Just reset factory settings and u'll get it back. I did exactly the same and upgraded to an italian version(?) and then i reset the factory settings and it was back there
