Rayman problem?
11 replies · 3,151 views · Started 29 July 2002
Does anyone else has a problem with the installation of Rayman?
It says that it doesn't find the Memory Card to install....
Can anyone help me?!? :cry:
Hmmm... thats weird!!! mine was installed perfectly... perhaps u should check your MMC??? oh man... this game RULES!!! bigtime...
I know what you mean... and I've boughted and the first time I didn't have any problem installing it...
but I had to reformat my 9210 and since then I can't install it again...
and my mmc works fine... that's the weird thing...
Anyway... thank you for your reply...
I'm trying to get arround that error 2 (trying to install it on the emulator)
In your case ... maybe if you copied it to you're mmc and then try to install it from the mmc it self, who knows it might find it then....
Good luck!
Everybody deserves that game!
I've tryed that also....
I'm waiting a response now from they support... :cry: :cry: :cry:
Anyway... thanks alot guys!
Hi guys,
Good that it's not only me having problems with Rayman. i have also tried to install it but while installing it gives me an error message NOTE INVALID
then when i try to register the game it's not giving me the phone key.
I can start the game though but again it gives me an error message, SOUND FILES ARE NOT FOUND and then ALL LEVEL NOT FOUND.
Any Clues???? :x :x :x :x :x :x :x :x :x :x
I heard of that error before, it complains but it still launches. The phonekey is usual the four last numbers of your imei.
Maybe a mail to support could solve your problem.
Good luck.
[quote="sabbath55"]Hi guys,
Any Clues???? :x :x :x :x :x :x :x :x :x :x[/quote]
weird...weird...weird... how come i didnt get all this problems??? everything was really smooth here... please also note that this game requires quite a large portion of space.. (around 4.5 MB for the 31 levels, music and sound effects...) perhaps that's the case???
and regarding the phone key, i registered mine without having to key in any phonekey... just the reg codes... (the phone key is actually already there...you just need to adjust the hue/contrast to see this... or just twist the angle a bit and u'll see the phone key...)
oh man, u guys should really solve the problems A.S.A.P coz this game is really WORTH IT!!!!
Another problem of Rayman is that it eats up the memory in the C drive as well. When I installed it. I found our it consumed around 5MB in my D drive, and around 1+MB in my C drive. Before I installed the game, I had 2.2MB in my C; after installing it, my C drive was around 800KB left.
😮 The game is awesome. but does it really eat up this many memory even if you installed it in the MMC?
Trouble installing Rayman could be because of no space for the temporary files on C:
Not having installed it on my machine (though I totally intend to), I cannot be certain, but I know that one of the reasons that 9210 users had problems getting 9210i software onto their machines was that the 9210 defaults to putting install files onto C: before actually running the install process. Of course, with the 9210i having more space, this wouldn;t be a problem for it.
I could (and may well be wrong) - but it's just a thought.
