is there a software to activate my 7650 mobile with a blue tooth to make and recieve calls???
Nadeem
bluetooth activation in 7650 for mobile use
Hmm... Could you try to explain in different terms what, exactly, you want done? At least I do not understand the question (or, namely, what "activating" in this context and especially what doing it with Bluetooth means).
[quote="Nads"]Hi,
Nadeem[/quote]
I think you're dreaming there, buddy. You can't 'call' someone over Bluetooth. You can send notes/photos though.
If you were to call somone over BT they would have to be quite close to establish a BT connection, close enough to speak to them in the normal way in fact!
Lee 8)
