hi, i just got smart profiles and i was really looking forward to have an animated gif in my background but there are NO decent ones anywhere, and yes i have tried google picture fault!
so PLEASE post your gif's.
PLEASE POST YOUR ANIMATED .GIF'S
You'll find alot of great stuff at http://us.bestgraph.com/.
Here's one of mine... any BTW, is there any difference between Smart Profiles and Extended Profiles? Does having an animated GIF as the background drain the battery faster? I use mine as my screensaver and I put it on a 1 hour sleep timer so that my battery won't drain out.
Heres my favorite!!
Darla, the battery will drain quicker with the animated background and it is also quite slow (i was dissapointed with the animation speed on eProfiles, perhaps they will rectify this in future updates of the software)
I bought eProfiles (so i can't comment on sProfiles) and i think it's pretty good. Automatic profile change etc all good! 😃
By the way loads of gif's on this thread
[quote="yourmanlee"]Darla, the battery will drain quicker with the animated background and it is also quite slow (i was dissapointed with the animation speed on eProfiles, perhaps they will rectify this in future updates of the software)
By the way loads of gif's on this thread[/quote]
I downloaded the trial of eProfiles and I already have Smart Profiles. The only difference that I can see is that Smart Profiles has the option of choosing a different Launcher skin for each profile. Thanks for the gif link!!
try this
Nice Gif Party Boy! 😊
Can you resize for 3650/7650 wallpaper? TIA
Lee
really?!? i didn't know it affects the battery life. is it the same when using animated screen saver? for examle analog clock or animated .gif?
Or try this
and this
repost 😃
http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=11367
[quote="i) 1 j2 t"][quote="yourmanlee"]Darla, the battery will drain quicker with the animated background and it is also quite slow (i was dissapointed with the animation speed on eProfiles, perhaps they will rectify this in future updates of the software)
really?!? i didn't know it affects the battery life. is it the same when using animated screen saver? for examle analog clock or animated .gif?[/quote]
In my experience yes it is. The battery doesn't last long anyway, but when you're running gif's as wallpaper/screen saver all the time it will reduce it yet further!
Lee
*I* like this one....
