How to take off a screen protector
5 replies · 1,649 views · Started 30 July 2003
Does anyone have any instructions as to how to take matrin fields screen protector off? I have some dust underneeth and its not straight, anyone know any sites which can show me how to take it off properly?
ok its off but how do i put it back on, do i remove all the stickyness with water? Its washable but will it stick back on (static i have been told)
I can remove most static covers with a piece of scotch tape. Apply a good piece of tape near the bottom of the screen protector, right in the middle/bottom of the phone. Make sure the tape goes all the way to the edge of the bottom. Pull up, and the protector should easily pull off.
Wash it with warm water and use a hair dryer to dry it off without watermarks.
The scotch tape method also makes installing the protectors very easy to do. placing a piece of tape to the top outside and bottom outside of the protector will give you handles. With these handles, you have more support and do not get fingerprints on the bottom of the protector. Be sure to have a can of air handy to blast away any dust.
A funny warning on the brando screen protectors says to remove the protector from the PDA before you wash it 😊
[quote="rickpaul"]
A funny warning on the brando screen protectors says to remove the protector from the PDA before you wash it 😊[/quote]
LOL, what next. open the screen protector packaging before applying
