Problem with Photo Editor 1.2
9 replies · 2,186 views · Started 04 August 2003
anyone else have trouble running the new 1.2 ? i tried many times installing and uninstalling, but whenever i run the app i get this error:
Program closed
Program Photo Editor
Reason code KERN-EXEC
Reason number 0
and before you ask where to get it from:
Handango
Bitween site
i thought someone was going to ask that .. yes i restarted many times .. actually i had to because after installing photo editor my application list would be blank so i had to restart to choose the app and run it ..
anyone else with this problem ? i emailed bitween and after waiting and waiting, i got an email which says they cant find my email in their system and want me to send them my order number .. well obviously he wont find it in their system if im using the TRIAL version :roll:
yes, we're having a little problem with trial ver, we got it mixed with the full ver 😉
Sorry about that, new and working trial version should be available for download in 15-30mins.
ok, as far as I know we have updated PE trial ver on both www.bitween.com and www.handango.com sites.
So hopefully everything will work fine now.
If you still have any problems and did try download from both sites please contact me at [email protected] and I will immediatelly deal with it.
Thank you for your help and sorry for this problem.
[quote="simply258"].. actually i had to because after installing photo editor my application list would be blank so i had to restart to choose the app and run it ..[/quote]
Actually, you could have also just ejected the MS Duo, wait until the apps re-appear, and than re-inject the Duo again! That will fix it too, and takes up less time...
