When I do *#06#, I get two extra digits at the end of the IMEI but on the sticker on the back of the phone I don't have the two extra digits. Problem is when I buy software which IMEI do I give?
N
N
😃 You should use IMEI number indicated in the box. You are right when you press *#06#, you get extra two digit, but you should not use that two extra digit. In the case of Tracker registration, program will pick up IMEI number without two extra digit automatically
of the top of my head, i remember the imei is 15 digits, usually one or two digits at the end are just misc numbers that aren't used at all
The last two digits will change on each firmware upgrade.
😃 The first 15 digit is your IMEI...
Thank you for your replies
Now I know what to give.
N
