what programs HAVE to be installed on the phone memmory to work?
i read somewhere that cameraFX has to be....any other progz?
progz on phone memory?
that's hard to tell... all progs that have to be installed in the phone's memory are most likely originally developed for the 7650. The game "Little Red Riddin' In The Hood" is such a game.
Most programs that you install use the phone's built-in memory.
Do not attempt to put more programs or else, you might encounter BIG problems.
8)
Just install the ones you only need or will help enhance your cellular phone usage.
That is VERY,VERY wrong!Most of the Series 60 apps have the MMC option right now,and you don't have to install them on the C: drive(phone memory)
Most likely,poeple get the idea that its not safe to install on MMC because of using cracked software,old incompatable version of an app or just a badly coded app.Don't mention snails,that game has been in beta stage for the last 8 months and its not being worked on for the last 6 months.
I install everything on the MMC... it all works fine with a couple of exception now and then... when that happens it usually just doesn't work... I uninstall it and reinstall it on the phone's memory.... Never had a problem with that
Exactly. All my progs are on the MMC and only IF they refuse to run from there do I install on the phone memory. Seems to be working for most people that way.
