Color Operator Logos
11 replies · 4,013 views · Started 09 August 2003
If you actually searched the forum you would've found many websites dedicated to Series 60 multimedia.You can find a couple here: http://www.allaboutsymbian.com/phpBB2/album.php
check this german site: http://logos.reallyboom.com/anzeigen.php?series=60
you con download a operatorlogo by using this URL: eg. http://logos.reallyboom.com/?00 (00 is the ID you find in the list)
Then you get a sis file that installs the operatorlogo to your phone. Works with PC and WAP.
[quote="MrPlow"][quote="Al3xandr3"]http://www.wascho.com/7650-oplogo
8)[/quote]
The problem with that method is that the folder described on there doesn't exist on my phone.[/quote]
Yeah, the method on there is confusing. Use FXplorer (or similar) to create a directory called 'Phone' under C:/System/Apps and cut and paste the logos from the images folder to this new one. Then simply use FXplorer's 'Set as Operator Logo' function.
To erase an operator logo and return to the network default simply delete the .bmp file that is created in the 'Phone' folder. Remember to reboot your phone for it to take effect.
Lee
Lee
Thanking you kindly!
As for that logo... hmmm... I might give it a pass party boy! hehe 😉
I'm going to make up my own in the form of a Ford logo! 😃
8)[/quote]
Install Fexplorer - the latest version has a 'set as operator logo' function when you highlight a file. It will even scale the image to the correct size if it is not already.
