System error "memory card"?
7 replies · 2,229 views · Started 20 August 2003
i need your help guys, whenever i put the memory card in my 3650 system error appears, but when i remove the memory card the is fone working normal again 😮 is there something wrong with the memory card. need help :cry: btw it's not mine actually, it's my sister's fone.
You try safe mode booting with the MMC inserted? If that does not work you might want to format the card in another device, such as a PC or a digital camera or say a Siemens SL45 phone. Then format the card with the 3650.
That's what happend to mine, I formated mine in a DV Camera and then in the 3650.
[quote="Kirill"]You try safe mode booting with the MMC inserted? If that does not work you might want to format the card in another device, such as a PC or a digital camera or say a Siemens SL45 phone. Then format the card with the 3650.[/quote]
How do you boot in safe mode? I've got a new card that is giving me a system error message & I don't have another device I can use to format it so the safe mode method is what I need to try.
[quote="The Party Boy"]i need your help guys, whenever i put the memory card in my 3650 system error appears, but when i remove the memory card the is fone working normal again 😮 is there something wrong with the memory card. need help :cry: btw it's not mine actually, it's my sister's fone.[/quote]
yo yo becareful wif it la.
have u ever try install Smart Launcher in the Phone instead of memory?
Well if so and the SL is in your memory; try install in the phone first w/o the memory card in it!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
then put the card back see how"""""""""""""""""""
it should be fine
HAHAHAHAHa :P :roll:
