is there a software like this for p800?
Torch for P800?
No, but there is something better!
A REAL TORCH.
IBT-20 costs around �4.99 and attaches to the bottom to the P800 (or any Sony Ericsson phone)
And it gives off a funky blue light.
Theres also a ultra-funky laser pointer attchment too, for around �15. (ILP-20)
http://www.expansys.com/product.asp?code=BTORCH
http://www.expansys.com/product.asp?code=LPOINT
Or you could use the mirror application (download it from my-symbian.com) and select the option white. It turns the screen completely white so you can use it as a light. Good enough for reading or finding your way in the dark.
[quote="Burns"]Or you could use the mirror application (download it from my-symbian.com) and select the option white. It turns the screen completely white so you can use it as a light. Good enough for reading or finding your way in the dark.[/quote]
thanks man
I got the torch, its cool! 😃 😃 😃
[quote="sidneylopsides"]I got the torch, its cool! 😃 😃 😃[/quote]
mirror?
I got the proper torch, i used mirror, but the backlight is only bright in the middle of the night (like 4.30 this morning whe nthe backlight started going on and off randomly) 😃 😃
sidneylopsides, you should have taken the torch (or even better the laser pointer) to the Test Match on "Jimmy Saville" day; taken out a few SA bowlers with it!!
yeah! i wanted the torch too............ but u dont hav much here in india... and i hd a friend going abroad but he couldnt find it...................... so im still waiting :cry:
