Does anyone know why the 3650 take more than 1 keypress at a time ???
Can make playing games very difficult ...
Just wondering as Psions used to use older versions of the Symbian OS & these where capable of multiple keypresses ...
Cheers
BSK 😃
Cheers
BSK 😃
bluescreenkid,I don't own a 3650 but i'm pretty sure that my 7650 has no problem with more than one keypress at a time.
-Edit-
My bad,i just tried pressing more than one key at a time while playing snake and it doesn't work.Its really strange,long time ago,i was playing Super Mario on GoBoy and i'm pretty sure that i managed to Run and Jump at the same time,on the other hand,i have a very small amount of healthy brain cells left. 😮ops:
GoBoy does support multiple key presses. However this only untily you multitask out of it. For example if you are playing GoBoy and recieve a phone call you will not have multiple keys working again until you exit out of GoBoy and reenter it. Not a problem since unlike some games on the console you can save at anytime.
So,i was not going mad,thanks for that Kiril 😊 BTW:I have noticed that too,when you task back to GoBoy,some of the keys are stuck(Not phisicaly)and you will usually end up with Mario running like mad in one direction 😊
