Ive been tryin to send info from 3650 to pc for ages it works fine the other way round but not 3650 to pc, ive looked at mega loads of forums about this topic and done 1 or 2 things but still nothin happens any1 have any ideas cheers all :cry:
BLUETOOTH 2 PC & PC 2 BLUETOOTH
I think this is what u need
http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=3075&highlight=sending+pc+bluetooth
:-? no ive already tried that chap and its already set to the correct setting so i dunno wot the hell is wrong but cheers anyway
strange, i had the same problem today, switched the drivers up a couple of times. Finally got the registry-entry AcceptOther back (even tried creating the variable myself, wouldn't work). Now it works. Got some other glitches right now though....
[quote="Blackwolf_67"]Ive been tryin to send info from 3650 to pc for ages it works fine the other way round but not 3650 to pc, ive looked at mega loads of forums about this topic and done 1 or 2 things but still nothin happens any1 have any ideas cheers all :cry:[/quote]
Problem is you provice no info on your OS version, what kind of BT adapter you are using, and what drivers, etc. For anyone to help you they need relevant info.
Sorry right im using operating system WINDOWS XP PRO, my bluetooth device is a BLUETAKE USB DEVICE and the drivers are the laestest Version:1.3.2.7 i hope that helps cheers all
Unfotunately have no experience with that BT device. My nameless one with Blue Manager recieves files fine but places them in a folder that it created in the root of C: called BTInbox. Tough place to find.
[quote="Kirill"]Unfotunately have no experience with that BT device. My nameless one with Blue Manager recieves files fine but places them in a folder that it created in the root of C: called BTInbox. Tough place to find.[/quote]
I think it's possible to change this folder by adjusting the following key in the registry "InboxDirectory" just search for this key in regedit. Hope this helps!
