http://nokia.iwebs.cz/viewtopic.php?t=951
PHOTOS TAKEN FROM N6600 !!
the details may not be that sharp but all in all it's still quite alright
Like i was expecting,slight if any improvement from the 3650/7650 camera.
doesn't give the 😮 effekt but it's aight !!
Bit difficult to make a judgement on this as the 6600 must be a prototype. The only issue really is how much the pictures would be improved with better software. That also assumes that the prototype doesn't have the finished picture software in it...
true, i remember seeing a prototype 3650 image and the resulting one is much improved
why dont they damn well increase the resolution of the camera!?
[quote="Anonymous"]why dont they damn well increase the resolution of the camera!?[/quote]Cost (of the sensor module, additional memory required, additional integration & verifcation/testing required, etc.). It'd most likely increase cost enough to take it to a new price range, which means fewer buyers, which means less revenue, which means that the initial price has to be higher, which means fewer buyers, which... 😉
Eventually it'll be economical enough.
That's the BCE, the Basic Cost Explanation. I wish it were it were the only one, because it's the most logical. Unfortunately, broadbeans are cooked everywhere (phrase from the Spanish "all� tambi�n se cuecen habas"😉. What I mean by that is that there are people and companies taking short cuts all the time, so that Logic does not always prevail. For a really extreme view of why euro phones are underengineered, try this for size
http//www.infosyncworld.com/news/n/2351.html
