where to put goboy roms so slauncher will detect them?
i have searched my whole phone memory and could not find and shortcuts for the apps or roms can some please give me the direction if this is possible?
thanks
goboy roms in slauncher menu?
lars,I'm not sure if i understood your question but i don't know what does sLauncher have to do with detecting gameboy roms or gameboy roms at all for that mater.I used to keep mine in my inbox.
i mean is it possible to keep your roms on your mmc and that slauncher will show them in thew menu do i have to place them in a special map or something, cause i keep them in my inbox to but i want to keep them in the slauncher menu is this possible?
Sorry lars,i don't think you can have gameboy roms in sLauncher's menu.With a little C++ knoledge,maybe 😉
thanks ghostdog but don't have the knowledge to do that 😞
You can keep them in any folder you like. To run them just use FExplorer or other file manager. You run the file from the file manager and it launches GoBoy. You only need to do this to change the game you are playing. Otherwise just launch GoBoy and play. To have those files show up in the menu will require some programming.
