error message ??
1 replies · 1,366 views · Started 09 September 2003
hi .. manan here .. i formatted my phone this afternoon .. it all
seems to be in order other than the fact that my applications folder
is not opening, each time i try and access it( there are no
applications installed). the :cry: displayed is "app closed
midpui" .. plzzzzzz help :cry:
by format to you mean *#7370#. If so what was the reason for the format. If you were experiencing problems they might be due to some errors that are on your MMC and the 7370 command does nothing with the card. So remove the MMC and try to run the phone without it.
If it is something else please provide more details including your FW version.
