How many people have 256meg or higher mmc on their 3650?
9 replies · 2,632 views · Started 11 September 2003
How many people here have 256meg mmc or higher running on their 3650 that DONT have any problems with slowing down or crashing due to the high memory.
If possible could you please put the make of the card so it gives newbies an indication as to what works and what doesnt and also your firmware version.
The more imputs the better
[quote="ceanth"]How many people here have 256meg mmc or higher running on their 3650 that DONT have any problems with slowing down or crashing due to the high memory.
The more imputs the better[/quote]
I got a 16 MB mmc card 😉
Were can i buy a 256meg mmc card?
im getting my 3650 today, i have heard that 3.XX and above can handle 256meg mmc, just wondered if anyone else has 256. check places like ebay for 256, i have even seen 512meg on there but not sure if it will work
256 From what I can gather some work and some do not. So it's best to test it in the store when you buy.
Its not firmware related.If you search the forum you will find brands of MMC's that work with the 3650,both 256 and 512MB.
Like Kiril said,Nokia does not support MMC's above 128MB,maybe because they don't make any.
From what I Understand it is not "truly" a firmware issue. It has more to do with the latency of the card. The firmware has a set time that it waits for the card to respond. If the card does not respond in that time the OS gives up.
Now with a newer firmware the latency wait could be increased.
Also Larger cards are by default slower
Better quality cards are usualy faster
High Quality + High Capacity = possibly ok
Low Quality plus High Capacity = Probably not
Viking makes "High Speed" MMCs that may work, this just means they have been tested before they are sold to be below some resonse time. For the life of me I can't find what their criteria is.
Hope this helps.
P.S. I run Viking Highspeed 128Mb from memorysuppliers.com for $64 US delivered
i am using 128meg mmc card viking
is works great,i bought it for 49dollars here in sweden =)
