anyone know of a way we can dump 3.16 to a file and people can download and install it ? thats for the people that cant afford , cant get , or too bored to go and get it , upgraded.....
DUMP 3.16 TO FILE
I have nearly finished writing a such program which allows to 'browse' or dump the memory of the Series 60 (3650 / 7650) in hexa/ascii but my 7650 is in the Nokia store to upgrade the firmware, whenever I receive it back, I finish the soft and post it on www.gosymbian.com ...
Cheers,
Domi.
Cheers,
Domi.
contact me dude. your the fexplorer author aint ya ? 😃 nice stuff . Can you give me the guidelines to which you would write such a program for the 3650 / 7650 ? Is there a function to which the phone will spill its data ?
btw the Z: drive is read only and if things could change there , then it would be nice since we can remove gay things like mixpix which my little cousin (3 years old) find discusting too 😊
Domi, are you actually saying that you are writing an app that allows to write to the ROM of the phone without proper and expensive hardware, that would be amazing but dangerous... BTW FExplorer rocks.
As far as I can read, Domi is only saying he's writing a program to dump (to a file, presumably) and browse = read the phone's memory.
He isn't saying anything about writing it.
I only browse ( = dump or read) the memory - I don't write in the rom !!! but some memory cells (or location) crashes the program, it seems that some memory areas are protected against the read ( !! ??? ). I have given my 7650 to Nokia to upgrade the firmware, normally, I receive it back today and whenever I receive it, I finish this app (I'm going to access the memory via a function written directly in arm assembly code...).
in the future (if ok), a dump to a file, memory search ....
Domi.
