9210 Fax Problem: When I press Write Msg I get not found!!!!
1 replies · 2,416 views · Started 14 September 2003
I had the SIM card properly configured and everything
was fine. Now, the following error is appearing when
I try to compose or receive a FAX msg. When
I try to compose I get NOT FOUND. And when
I am getting FAX msg. the Communicator would
not answer.
Thank you for your cooperation.
With regards,
Rashad
