[quote="dswskinner"]The 7650 is a phone with (some) PDA capabilities - It has very limited Calendar and Contacts functionality and you are able to install a very limited amount of 3rd party programs[/quote]
You're right, the 7650 is just too limited for its price... 😉 And, if it's so limited like you say, then why would anybody want to buy it?
[quote="dswskinner"]The P800 is more like a PDA with phone capabilities ( like the XDA, but not as good). And yes i would call having a touch screen with handwriting recognitin a function of a PDA. [/quote]
The P800 is a phone with PDA functions, and the XDA is a PDA with phone functions. There is a difference, the XDA is just too wide to be used as a normal phone. And, it uses crappy M$ software. :evil: I like the P800 more because I need a phone more than I need a PDA (and I do need both) and I don't want to be holding a plate to my head when making a phone call. 😃
[quote="dswskinner"]As i said before, i think that the P800 should be compared with the 9210 or even The XDA (Which i believe is an altogether better system) and not the 7650.[/quote]
OK, so with what can you compare a 7650 if not P800? Can somebody, please, explain to me what is the purpose of this phone, if that purpose is different from the one of P800?
9210, on the other hand, IS a different category than these two phones, you can't really compare it with P800 nor even XDA. And you think that the P800 is more similair to the 9210 than it is to 7650?!? Did you even look at these devices?
I think that you don't want to compare these two phones just because it is so obvious that the P800 kicks 7650's ass big time. 😃
@Andy:
Like I said before, you CAN use the P800 with only one hand. And what makes you think that the 7650 is much more compact than the P800?!?
