1. There is one word in the English language that is always pronounced incorrectly. What is it?
2. A man gave one son 10 cents and another son was given 15 cents. What time is it?
3.. A boat has a ladder that has six rungs, each rung is one foot apart. he bottom rung is one foot from he water. The tide rises at 12 inches every15 minutes. High tide peaks in one hour. When the tide is at it's highest, how many rungs are under water?
4. There is a house with four walls. Each wall faces south. There is a window in each wall. A bear walks by one of the windows. What color is the bear?
5. Is half of two plus two equal to two or three?
6. There is a room. The shutters are blowing in.There is broken glass on the floor. There is water on the floor. You find Sloppy dead on the floor. Who is Sloppy? How did Sloppy die?
7. How much dirt would be in a hole 6 feet deep and 6 feet wide that has been dug with a square edged shovel?
8. If I were in Hawaii and dropped a bowling ball in a bucket of water which is 45 degrees F, and dropped another ball of the same weight, mass,and size in a bucket at 30 degrees F, both of them at the same time, which ball would hit the bottom of the bucket first? Same question, but the location is in Canada?
9. What is the significance of the following: The year is 1978, thirty-four minutes past noon on May 6th.
10. If a farmer has 5 haystacks in one field and 4 haystacks in the other field, how many haystacks would he have if he combined them all in the center field?
11. What is it that goes up and goes down but does not move?
1. "incorrectly"
2. 15.26 right now
3. none
4. white (well, it looks white at least :P with a black nose)
5. three
6. Sloppy is a goldfish? The bowl blew off and broke?
7. none
8. the one at 45F in both places - the other is a bucket of ice
9. 12:34 5/6/78
10. um... there's got to be a trick to this one I'm not seeing!
11. temperature? stocks and shares? the sun?
[quote="kishor"]1. There is one word in the English language that is always pronounced incorrectly. What is it?[/quote]It is "incorrectly".
[quote="kishor"]2. A man gave one son 10 cents and another son was given 15 cents. What time is it?[/quote]About 17:43 here now.
[quote="kishor"]3.. A boat has a ladder that has six rungs, each rung is one foot apart. he bottom rung is one foot from he water. The tide rises at 12 inches every15 minutes. High tide peaks in one hour. When the tide is at it's highest, how many rungs are under water?[/quote]Zero.
[quote="kishor"]4. There is a house with four walls. Each wall faces south. There is a window in each wall. A bear walks by one of the windows. What color is the bear?[/quote]White.
[quote="kishor"]5. Is half of two plus two equal to two or three?[/quote]Three.
[quote="kishor"]6. There is a room. The shutters are blowing in.There is broken glass on the floor. There is water on the floor. You find Sloppy dead on the floor. Who is Sloppy? How did Sloppy die?[/quote]Drowned.
[quote="kishor"]7. How much dirt would be in a hole 6 feet deep and 6 feet wide that has been dug with a square edged shovel?[/quote]Nothing.
[quote="kishor"]8. If I were in Hawaii and dropped a bowling ball in a bucket of water which is 45 degrees F, and dropped another ball of the same weight, mass,and size in a bucket at 30 degrees F, both of them at the same time, which ball would hit the bottom of the bucket first? Same question, but the location is in Canada?[/quote]They'd all hit the bottom at the same time.
[quote="kishor"]9. What is the significance of the following: The year is 1978, thirty-four minutes past noon on May 6th.[/quote]12346578.
[quote="kishor"]10. If a farmer has 5 haystacks in one field and 4 haystacks in the other field, how many haystacks would he have if he combined them all in the center field?[/quote]One.
[quote="kishor"]11. What is it that goes up and goes down but does not move?[/quote]Escalator.
No more to solve,do you have more kishor?
How can a Fish Drown? Wouldn't it have Suffocated as couldn't breath in Water?
Is this a riddle too? the fish suffocating?? 😮
[quote="Jadeviper"]11. temperature? stocks and shares? the sun?[/quote]
I think that "The temperature" would be he right answer as the Stairs on an Escalator move.
Also What about Sound Volume! You turn the Radio Volume up or Down, but doesn't move, does it?
New One:- A horse travels a certain distance each day. Strangely enough, two of its legs travel 30 kilometers each day and the other two legs travel nearly 31 kilometers. It would seem that two of the horse's legs must be a kilometer ahead of the other two legs, but of course this is not the case. Since the horse is quite normal, how is this situation possible?
it's going round in a circle so the outside legs are travelling further.
What do the following words have in common?
age, blame, curb, dance, evidence, fence, gleam, harm, interest, jam, kiss, latch, motion, nest, order, part, quiz, rest, signal, trust, use, view, win, x-ray, zone
It is not that they are in alphabetical order!
I have no idea on this... is it related to the number of letters in each word?
Is it that when they're all put together in a list, it's really difficult to see a connection between them? 😃
All of them can be either a verb or a noun.
Now then, how many animals did Moses take on the ark?
a male & a female of every species.
Moses didn't take any animals onto the Ark.
i thought the animals went 2x2?
yeah, but it was Noah who took them, not Moses 😛
i think i need glasses. i didn't even spot such an obvious mistake.
it wasn't a mistake - it was deliberate and designed to catch you out exactly as it did 😊
Whilst I was engaged in sitting I spied the dead carrying the living. Whats the Answer?
the Answer? I didn't even see the Question!
There's nothing that google couldn't solve. The answer is Ship.
Not sure if I get it though... 😕
engaged in sitting... I couldn't get public toilets out of my head!
the ship must be the dead - dead wood?
Originally posted by Jadeviper
is what a lighthouse?
the answer to gadgets question? Whilst I was engaged in sitting I spied the dead carrying the living. a lighthouse sits on the edge of a cliff & would spy boats carrying passengers
a lighthouse is an inanimate object - it can't see things.
i didn't know we had to be exact about what way we understand things.
the riddle though implies that the watcher is living
