I just got to use a 9210i for sometime now.
Im not to impressed with it.
Firstly it does not come with a Card..only the internal memory has been increased, so u will have to buy a MMC card seperately.
For some reason i could not use my older Cable to sync the 9210i to my comp. I had to use the cable that came with it. I'll have to check my cable.
If you dont have a MMC card then the memory runs out very fast if u load all the software in C:
But yes when i got it, there was no software loaded & teh apps opened very very fast. The memory increase is the only real good thing i think.
I did not get the CD so i dont know what's on it.
Anyways with a MMC its an xalant phone.
The front buttons(keypad) are silver in colour.
Software Version was like this.
V 05.33
10-04-02
RAE - 5
Check out the pics.
Ciao
HyPeR
