Every time i install IM+ and go to open it before the program loads up it exits and gives me a SYSTEM ERROR! message??? What gives? Whats causing this and what can i do to make it usable?
IM+ System Error?
Any difference depending on whether you install it in phone memory vs. memory card (MMC)?
i installed it on my MMC and it has like 8mb free
try agile messenger!
http://www.agilenoc.com/beta/
[quote="Kastel07"]i installed it on my MMC and it has like 8mb free[/quote]Then try installing it in phone memory and tell us if it makes a difference. If it does, complain to whomever wrote the program.
i dont have a gprs service and it didnt ask me how i want to connect to the internet? i think it might be connecting through my computers internet? Does chatting on this cost money?
Depends on the channel you use and what your agreement with your service provider is.
agreement? If i dont have any internet acces from my provider then how can i have an agreement all i have are minutes and text messages and i want to just go online with IM+ using my bluetooth. and when i logged on AIM it didnt even ask me how i wanted to log on it just went on so i dont know what internet its using either my internet from my computer or the GPRS i didnt sign up for?
If it's using GPRS you will see a G in a box instead of the antenna icon beneath your signal meter. If it is using your PC internet access then you may still be paying depending on your agreement with your ISP.
