is there a way to develop a software that you can locate all bluetooth device on you phone? just like a radar, so you could now how far or which direction of the device is located, just like in an anime DRAGON BALL, they use a device to locate a dragon ball. so you could now how far is the other divices near you, not just knowing but locating them as well...
and how can attach a MIDI to the MMS or a wav file? is there a program can do this? my operator (Globe Telecom) can send MIDI on their MMS, but when i try on FExplorer, it cannot attach the file...
I don't know of such software, apart from trying to send something (e.g. Phonebook entry) via bluetooth so that the phone scans the area.
As for MMS, NOKIA does not allow attaching such files in its MMS editor, probably to "protect" copyrights! :x There is a program that can attach MIDI files, though: CoolMMS
that software would very cool. It would also work like a compass, finding its north/bluetooth.
But, be honest.. don't you want that software to locate the babes using bt? 😃 I would!😉
[quote="Al3xandr3"]that software would very cool. It would also work like a compass, finding its north/bluetooth.
But, be honest.. don't you want that software to locate the babes using bt? 😃 I would!😉[/quote]
that's right! i should be like a compass to be able to locate someone or something...
That's number one reason... to locate someone...
and number two reason would be finding your phone, incase your phone is misplace in the house, can't find it, and your bluetooth is on, you could locate much faster than the conventional way screaming WHERE'S MY PHONE! 😃
i hope someone could make this software...
it will sure be a smashing software!
Yep, it would be cool. The only question is: Would it be possible? 😊
i hope its possible...
it just like searching bluetooth device but has a graphical user interface that would tell the direction, distance of the bluetooth device... then has a function to refresh after certain minutes or seconds...
and able to send a file especially text document (costless SMS via bluetooth)
and you will be knowing what kind of bluetooth device or cellphone there using
