Can't Format?
1 replies · 1,345 views · Started 20 September 2003
I unable to format, I tried pressing Ctrl Shift and F, but it doesn't work anymore. When you press the buttons, only the Shift makes no noise (thus not responding). Is there any other way of formatting?
The reason for the format was that some buttons on the screen and the Shift button no longer work?
N
If thats the case, its not your system thats got corrupted... its time for you to change the 9210 Flexi Cable which connects both your keyboard and LCD...
it might also be just the dust...
