Hi programmers,
it can't be that you - during development cycles - don't come to a situation where you have to format your phone to delete some buggy alpha release.
HOW do you do this ?
Please let us not die alone :-?
Thx, Andy
Hi programmers,
Thx, Andy
did you try, www.forum.nokia.com ..? you can find a lot of stuff there, related to 7650 and series 60 based developement..
Yes,
thanks for the tip. The only recommendation they have there is sending the phone in for reflashing the software. But it does not solve the problem, really.
Andy
There is a program which allows to reset the phone to factory settings - the Task Manager from PsiNT - but I did not try it for obvious reasons 😊
