Problems with MP3Go!!
6 replies · 2,522 views · Started 01 October 2003
I have a couple 1 hour long mixes in mp3 format. When I play these MP3Go doesnt continue further than approx 30 min. All of the files are ok. I have tried them in other players but MP3Go jams.
Any suggestions??
=)j
I think it's about memory too but... Files are encoded at 48kbps and are about 26MB each. My 3650 has usually about 1500k memory free so why does these files jam after 30min.......??
=)j
i'm not really sure what i'm talking about here but i took this from the m-internet site.
"Support MPEG-1 layer 3 file in 24K/32K/64k/128k/256k/320k bitrate"
maybe you need to encode the mp3's to one of the above bitrates? you said you have the files encoded at 48kbps.
Hmmm.....
Tried 32k, 48k, 64k and the player jamms in all files at 33min 16sec. 😞
Is there anything else I can do than cut these wonderful mixes into 30min clips?!
Thanks!
=)j
If it stops always @33:16 then the problem most likely
is in the player software. Now if you have bought the
software, then you should be able to ask the developer
to fix that limit.
Just write them an email, and ask nicely 😊
