hey guys i need help i just bought a new mmc card for my nokia 3650 but i bought a game from gameloft.com that i installed into the original nokia 16mb mm card. how can i move the file from my old card to the new card? thanks
kevin
kevin
Option 1: Make a backup with PC Suite (after you've removed relevant lines in BackupExclusionList.dat or at least c:\system\mido) of the phone + memory card. Restore backup to new memory card.
Option 2: Use a PC-based MMC reader & copy the files to the PC using that and then back to the new card.
Do you not have the install files anymore. Try contacting the place you bought it from they may just send the necessary files to you again.
